To boot from usb mash f11 when booting and when in the boot menu you will hard drive as a boot option but when you use the arrow keys to highlight it, it will show usb as a boot option. To view raid pay attention as it is booting up and when it shows perc 6i controler (or something simular) it will also say to view config press [ctrl]+c or [ctrl] +r or something like that.
Folding Community Board:
Also check out our Official Folding Month event:
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817578
Ok, yeah there's my problem, I can't even see my RAID inside the config i don't think, i spam f11 and all i get is this:
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817591
1 minute ago, Electronics Wizardy said:
Id switch from unraid on a r710, esp with a raid card, Just install the os on the sd card or on one of the drives.
What do you mean? I want unraid to make VM's Do my NAS, run Plex, openVPN etc. its been very good for me on my other machine.
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817593
If you just go this reset the bios, usb boot could have been disabled.
You should see a perc menu pop up.
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817598
Unraid its really ment for use without a raid card.
And there are many other hypervisors for running vms, and are much better at running vms with many more options and are free. Look at proxmox, esxi, and hyper-v server.
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817602
Running unraid on a system with a raid card in it instead of an HBA just isn't the greatest idea it puts you at a greater risk of data loss.
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817603
this is a temp doing to make sure the server runs before my 14 day return ends. i plan on getting a HBA RAID card.
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817606
to get into the bios and view boot options when booting it up press f2 and from there you can look at boot option and order and make sure it had raid card in there as well as usb option.
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817627
Just pop the battery out for a minute and it will be reset.
This is the equivalent of clearing cmos on a motherboard. I personally would check bios settings first before doing this. In the bios there is usually an option to restore factory defaults and this is safer than poping the battery out.
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817633
Couldnt find the default reset button but Internal USB was turned off, ive turned it on.
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817651
What specific card do you have in there?  If you aren't getting a RAID configuration prompt at boot like CTRL+R  then either the card is missing or not working.    I've seen a few chassis with an empty expansion/RAID slot.
I have a few poweredge like 610, 720, 430 AMA
Which specific one?  Stating HBA and RAID at the same time is kind of contradictory.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817652
2 minutes ago, Oli1549 said:
Ok, so. I found some cyan coloured screen, the raid setup or something. i clicked some buttons not sure what and the hard drive is now a "virtual drive" and is showing up, i loaded through the drive and booted from usb which loaded unraid i believe.
That would be your raid config screen. You will definitely want to get comfortable with it as that is how you configure drives for the system.
https://linustechtips.com/topic/978935-dell-r710-help/#findComment-11817675
