What will the speakers be used for? Phone connection, laptop connection, etc.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/978826-audioengine-a5-wireless/#findComment-11816234
These are very highly reviewed speakers, which leads me to believe that their connection should be very consistent. However, I've used a couple wireless speakers with my PC, it's not nearly as hassle free as a wired connection, so it's worth considering a wired option to go with the wireless speaker to alleviate any possible headaches.
Primary PC:
PSU tier list
https://linustechtips.com/topic/978826-audioengine-a5-wireless/#findComment-11816262
They can be connected with wire as well, but I want to connect them with my google home mini with bluetooth. They cost 500 dolars so it's quite a lot.
https://linustechtips.com/topic/978826-audioengine-a5-wireless/#findComment-11816295
Personally I would look at powered bookshelves or passive from companies like JBL, SVS, Emotiva etc.
Since you’re going to have to send power to each one anyways, I would say search for passive with a receiver or Dac/amp as separate.
CPU: i7-5820k (4.7GHz/1.292V)                             RAM: Cruital Ballistix Sport 16GB DDR4                                Case: NZXT H440 Razer Sound: SVS Ultra Bookshelves / SVS SB13-Ultra / Marantz SR7008
Cooler: Dark Rock Pro 3                                         Storage: Samsung 840 Evo (500GB)  + WD Black (1TB)    PSU: EVGA G2-1000        M/KB: Razer Ouroboros / Blackwidow Ultimate Stealth
Mobo: MSI X99S Sli Plus                                         GPU: EVGA 1080Ti Hybrid                                     OS: Windows 10               Monitor: BenQ XL2720Z / Asus PG348Q
https://linustechtips.com/topic/978826-audioengine-a5-wireless/#findComment-11825094
