I currently have a EVGA GeForce GTX 1080 Ti FTW3 GAMING, 11G-P4-6696-KR, 11GB GDDR5X and I never see all three fans blowing. I have tried to do research and it appears that the fans are asynchronous and will only spin when it becomes too hot. I was wondering if the three fans will monitor and work on their own even if I don't have the EVGA Precision XOC application installed. I couldn't find anything on the internet about it needing PXOC in order to work properly. I only saw articles saying that I should install PXOC if i wanted full control of my fan curves, RGB, etc. I don't really care for that level of control or features and just want to know the fans on the card will work properly without PXOC.
Thanks for clarifying.
https://linustechtips.com/topic/977608-precision-xoc-required/
The bios controls them as set by evga. You don’t have to do anything. Run a benchmark or game and check on them. Should all be spinning at some point. Especially inside a case.
https://linustechtips.com/topic/977608-precision-xoc-required/#findComment-11804980
