Hey folks my build is underway. However im experiencing some difficulty with motherboard installation due to foam being on the back of my I/O shield. It seems to be preventing the mobo from being aligned with the standoffs. Any advice would be appreciated. Thanks!
Edit: forgot to add that  im building in an h500 case.
Edited by cerberus_truther
https://linustechtips.com/topic/977580-build-helpmotherboard-installation/
Foam I/O shields can be squished to make room for the motherboard, but also make sure the I/O shield is inserted entirely
Primary PC:
PSU tier list
How many watts do I need?
those pics are blurry so it's not particularly easy to tell how far in the I/O shield is but maybe it could use some coaxing, but it looks pretty thicc so you should be able to squoosh in the motherboard.
Primary PC:
PSU tier list
