Problem : After playing Fortnite for about 2 games ( about 50 minutes ), my CPU usage drops from about 20% to 11% , causing FPS to drop from 200-350 to 120-180.
System specs :
Prime deluxe x299
i9 7900x ( Changed specific core ratio to 40 on 8 cores and 41 on the * cores ).
4x8 gb 3200 MHZ corsair vengeance lpx XPM profile enabled. Quad channel
1080 gtx ti aorus xtreme
850W power suply EVGA gold.
EVO 212 cooler.
Benq xl2540 , 240 hz
Power plans are all on maximum performance. Temperatures are stable at CPU 60 C and GPU 67 C.
Observation : After I restart my computer all comes back to normal and it takes about 2 games for the CPU usage to go down along with the frames.
Observation 2 : When I was using duo channel 3200 Mhz XPM enable, but with default settings on core ratio ( core by usage ) , it was taking longer to happen, about 3 hours of gaming.
Observation 3 : When I upgraded Duo channel to quad channel , XPM enable, it didnt even happen.
But after changing on bios the core ratio to 40 on all cores except on the * ones, I put 41, it started to happen only after 2 games ( about 50 minutes ).
https://linustechtips.com/topic/977183-cpu-usage-drop-along-with-fps-drop/
