I have a p8z77-i deluxe with a 3770k and 16 gb of dominator platinum. The motherboard and ram create clearance issues so I picked up a h80i v2 liquid cooler.
this system is just going to to be for lower power web browsing and streaming, not gaming so im getting a passively cooled 1030 so that i can hook it up to my spare 4k monitor.
Im looking for a compact case with no particular budget in mind. Cheaper is better because this is really just a web box filled with spare parts.
Features i would like to see in the case
- Compact, not a tower style case.
-being able to use the h80i v2 as exhaust not intake (if possible) while having an intake fan.
- atx psu support would be nice too but not needed would cut down on cost but i dont mind buying an sfx psu.
Here is where I would keep my frolics if I had any.
https://linustechtips.com/topic/976685-compact-itx-case-suggestions/
Shoebox or yellow-page sized?
Desktop benching:
10 minutes ago, #Banana said:
Well, shoe box would be better for airflow but im open to whatever as long as it works.
Now that I think of it, only shoe box ones can carry an AIO and give enough airflow for a passively cooled graphics card :P
Then my recommendation will be the Cooler Master Elite 130 and Silverstone - Sugo SG13B. Both are compact and both support 120mm AIO like the H80. The problem is that both violate the requirement of using the AIO's radiator as an exhaust. You will therefore need extra intake fans to not cook the graphics card with the warm air pulled in through the radiator.
To fit that 'radiator as exhaust' requirement, the Fractal Core 500 should do. It is a bit bigger than the other two though.
Desktop benching:
