Hello!
I'm looking for a pre build pc, my budget is around $400.
I want it able to play games like overwatch and fortnite at mid-high settings.
If $400 seems not enoght for you to get a fully build pc with a dedicated gpu, you can find one for around $300 and I'll just upgrade it with a Gtx 1050 or a Gtx 1050ti.
https://linustechtips.com/topic/976642-best-pre-build-pc/
14 minutes ago, LukeSavenije said:
If they were to buy that, I would strongly recommend that they replace that system's PSU.
That thing is shocking.
I just had a look on Newegg, looked for a PC with an SSD and a decent CPU. I found this
https://www.newegg.com/Product/Product.aspx?Item=9SIAEYA81P5014
Ryzen 3 HDD, no SSD
https://www.newegg.com/Product/Product.aspx?Item=9SIA24G7AY0071
i5 HDD, no SSD
https://www.newegg.com/Product/Product.aspx?Item=N82E16883288108
https://linustechtips.com/topic/976642-best-pre-build-pc/#findComment-11796342
so that pc and a psu like this: https://www.newegg.com/Product/Product.aspx?Item=N82E16817139147&cm_re=cx550m-_-17-139-147-_-Product
it's a little over budget, but it will work great and you'll have some space to upgrade to an external gpu.
https://linustechtips.com/topic/976642-best-pre-build-pc/#findComment-11796352
It's not worth spending the extra $15 for a CX550M over a CX450M. Plus the CX450M has a mail-in rebate, so it can be only $26.
https://www.newegg.com/Product/Product.aspx?item=N82E16817139146
https://linustechtips.com/topic/976642-best-pre-build-pc/#findComment-11796430
