Sorry if I'm on the wrong page, I'm building a PC for a client.
He's building a system for his 61 year old dad, his request :
Must be able to play these games at 1080p 70 frames or higher
Smite
Overwatch
Battlefield 4
Cs go
and standard internet and YouTube
Questions I have :
Ryzen G2200 or G2400?
Will 8gbs do?
Does he need a RX 570?
No need for stand alone gpu?
Best Value Build List
Budget 1080p System (RGB) https://pcpartpicker.com/list/7v2Lmq - (this build comes with two free games with the RX 570)
https://linustechtips.com/topic/976515-need-help-with-build/
Budget?
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795185
10 minutes ago, bleedblue said:
Budget?
Well he put $900 with me for the build, I'm going matx cos I don't think he'll need a 2nd gpu.
As for case I'm going with a fractal meshify c mini
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795225
PCPartPicker part list: https://pcpartpicker.com/list/8f8LbX
Price breakdown by merchant: https://pcpartpicker.com/list/8f8LbX/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($165.99 @ Amazon)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($19.99 @ Newegg)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($79.99 @ Newegg)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($134.89 @ OutletPC)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($59.99 @ Adorama)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($71.89 @ OutletPC)
Video Card: Sapphire - Radeon RX 580 4GB NITRO+ Video Card  ($229.95 @ Amazon)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($38.98 @ Newegg)
Total: $801.67
Assuming peripherals not included. This will breeze through those games @ 1080p. It'll pump out way more than 70fps.
Case will be up to you.
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795238
Total: $801.67
LOL overkill much?
A 2600 for a retired soldier who trying to relax.
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795245
1 minute ago, Galion said:
LOL overkill much?
Maximizing the 900 usd budget lol
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795247
LOL I guess so but I don't want to force my client into stuff he doesn't need
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795256
Everyone needs more frames. /s
Seriously though, you can get rid of the GPU, CPU and replace them with a 2400G.
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795279
Thanks so no gpu needed?
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795282
If he's ok with medium settings on Overwatch and BF4.
If not, slap on an RX 570.
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795302
Thank you
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795326
Wut.
Also, 61yr old gaming dad, way to go B|
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11795559
9 hours ago, Galion said:
LOL overkill much?
If it's overkill while being in budget then I think it's not overkill. Personally I would use an i5 8600 ($240 on ebay) with a 1060 3gb ($125 on ebay) or wait for zen 2 chips.
sauce: https://www.ebay.com/itm/ASUS-NVIDIA-GeForce-GTX-1060-3GB-Phoenix-Fan-Edition/323469833678?epid=6017533738&hash=item4b504df5ce%3Ag%3Al5MAAOSwX2xbrH-h&LH_BIN=1
https://www.ebay.com/itm/Intel-Core-i5-8600-Coffee-Lake-6-Core-3-1-GHz-LGA-1151-BX80684I58600-Processor/173536491399?epid=24018207796&hash=item286794b787%3Ag%3AAuMAAOSwdC1bnN5n&LH_BIN=1
https://linustechtips.com/topic/976515-need-help-with-build/#findComment-11796319
