I just upgraded from a GTX 960 to a RTX 2080.
I have two monitors.
     -A 1080p 60hz DVI/HDMI
     -B 1080p 144hz DVI
I have a HDMI to DVI but it only gets 60hz when connected to B.
I have a display port to HDMI connected to A.
What do I need to do/buy to get 144hz on B?
I'm looking for the cheapest solution.
-Sarah
https://linustechtips.com/topic/976475-upgraded-graphics-card-low-fps/
Buy something that supports 144Hz through DP or HDMI.
Hitting 1080p 144Hz with DVI require dual-link DVI, which needs an active adapter (includes a chip inside) to be converted from HDMI or DP. Passive ones (i.e. those without the chip. Doesnt matter if they advertise dual-link DVI for a passive cable, it just doesnt work) limit you to Single-link DVI which is limited to 1080p 60Hz. That's the problem, since DP to dual link DVI adapters are unreliable, and HDMI to dual link DVI adapters are nearly non-existent. Not to mention they arent cheap.
Desktop benching:
So you are saying I should get a DP to DVI 144hz?
I can't seem the find any on amazon that go above 60fps.
Know where I can find one?
I'm saying it's time to give up that monitor, just with explanations.
Desktop benching:
8 minutes ago, Sarah NeedsHelp said:
Do you haven any ideas that don't entail buying a new monitor?
New monitors are very expensive.
no. Adapters break easily or are expensive, so they are just as bad as spending a fortune on a new monitor.
That's a very ironic thing for someone who just bought an RTX card to say
Desktop benching:
