Hey I’m  building a pc for 2000 CAD
minimal gaming hence the 1050ti
some video editing and rendering but mostly cpu intensive tasks
i do want rgb though....
so what do you guys think
heres the updated permalink https://ca.pcpartpicker.com/list/PKFNBb
btw upgrading from
i2 8200
asus p5kpl cm mobo
3 gb ram
500 gb hdd
no gpu
stock cooler
unidentifiable coolermaster psu
720p monitor
no pics sadly
Edited by Jas99
https://linustechtips.com/topic/975681-first-pc-help/
8 minutes ago, Jas99 said:
i2 8200
not sure what this is, I think you mean core 2 duo
your permalink gave a 404 so I can't read the PCPartPicker list, sorry.
Might want to edit your first post
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/975681-first-pc-help/#findComment-11787241
3 minutes ago, Jas99 said:
Updated the link and cpu I the i2 Q8200
4 cores, 4 threads
locked processor at 2.3 ghz.
There we go.
Build looks pretty balanced, I've used that motherboard in a build, quite good.
For reference, there's no such thing as an i2, that's a core 2 quad.
Primary PC:
PSU tier list
https://linustechtips.com/topic/975681-first-pc-help/#findComment-11787267
Thanks! Any potential incompatibilities? Adapters or splitters or anything I would need?
Looks like the case doesn't come with fans, grab a couple noctuas for some good quiet cooling.
Primary PC:
PSU tier list
https://linustechtips.com/topic/975681-first-pc-help/#findComment-11787288
