Hey there fellas. I've got a server that runs here at home that I use for network backups and whatnot. Its a pretty basic build, it has 2 7200 Seagate drives, an Athlon 2 X4 640 (OC'd to 3.7ghz), onboard graphics, and 8gb of DDR3. I've got a 450 watt Thermaltake PSU that came with an old case a few years ago, that would work fine, but for some reason it just can't power the 2 drives at once. Running a single drive it does fine. I've also got a Corsair CX500W that can power everything just fine, and once booted is flawless. However, whenever I do a full power down and try to boot back up it becomes a nightmare.
Everything in the PC powers on, fans, lights, HDD's, etc. but there will be no video and the motherboard doesn't beep. The other day I just ripped the power cord out of the back, plugged it back in, and it booted and ran for several days. Once again today I'm having the same issue, and that "solution" doesn't work. The Thermaltake PSU will boot just fine (with one HDD) but the Corsair will not. Currently I have the Corsair powering just the hard drives while the Thermaltake handles the CPU and motherboard and its running without issue. Anyone knows whats going on here? Thanks!
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/975598-sporadic-psu-booting-issues/
