Confusion Between SSD Interface Types
Go to solution Solved by homeap5,
Take whatever you like. NVMe SSD uses the same lanes as PCI-E interface SSD, so depends on your motherboard - you may want to buy PCI-E version (if you have lot of empty PCI-e slots and none M.2 slots) or M.2 (if you don't want to block your PCI-E slot and have empty M.2 slot).
About SATA M.2 - they uses the same interface as normal SATA drives, with the same limitations - so if you want faster drive that normal SATA drive - avoid them. But if you want cheap drive for system, with no wires etc. - take SATA M.2.
If you want to load programs and system faster - SATA or M.2 SATA will be the same fast as M.2 NVME or PCI-E. If you want to have fast drive for video processing etc. or just have lot of money and want to have "the best possible drive" - buy NVME.
Good day,
I am looking to upgrade my PC and I am looking to purchase a faster NVM-E SSD, but unfortunately the terminology is majorly confusing me.
In terms of interface types, you can get:  2.5" SATA,    SATA M.2,   M.2 PCI-E    and    PCI-E (I could stand corrected).
Herewith attached are examples of two types of NVM-E SSDs which I am considering.
Please make reference to the images when providing an explanation.
Any advice is greatly appreciated.
"That is from an obscure language known as French- Mr. Data, the french language for centuries on Earth represented civilisation- But surely sir... - I suggest you drop it Mr. Data" - ST TNG
https://linustechtips.com/topic/973771-confusion-between-ssd-interface-types/
2 minutes ago, leviathan1701 said:
Good day,
The first image you linked is a PCIe NVMe SSD. This uses the PCIe form factor, and the PCIe x4 bus for NVMe.
Second image is an M.2 NVMe SSD. This uses the M.2 form factor, but still the PCIe x4 bus that NVMe requires.
The only real difference is price and form factor.
