Drawer PC Project
Go to solution Solved by Gawron10001,
@huilun02, thanks for comments, but i abbadoned the project because i just bought server rack :P
Hello
Recently I was thinking about putting my pc under my desk, i have dog and 3 cats, so i have to clean the filters reallly often. I don't want to put compontents directly uder the desk, i want to make wooden box, put all pc components and mount it on rails under my desk. It doesn't have to be super preety. So here is my plan
This is made in scale 1:5 and componets are a little bit bigger, so it is easier to draw it on the paper
So, first at all, i have ssd, this is least important here for me because it can be anywhere
Second thing, where the arrows are there are fans
Third, thing, gpu will be side mounted, i'm thiniking about changing cooling solution to taller fins, something like this, and add smaller fan inside, also make some sort of tunnel, from the one of the fans. This is gtx 1060 3gb so i don't know if it's necesary, and same story with the cpu basicly
Znalezione obrazy dla zapytania heatsink
And i think that's it. The next update will be when i will start cutting wood
I will be glad if you want to leave any suggestions or opinion
Quote me so I can reply <3
https://linustechtips.com/topic/973696-drawer-pc-project/
27 minutes ago, huilun02 said:
Where and how is your PC currently positioned?
Identify and address the actual cause of the clogging filters. If its placed where your cats and dog can reach, shift the PC to where they can no longer do that. If its on the ground where the fans easily suck in all the hair and dust, then dont put it on the ground.
On the floor, and i have actually no other place to put the pc, i tried to put it on desk but it didn't work out for me. I was thinkin putting it on some sort of higher leg stand like 30cm above the ground but i don't know how it would workout
Is your 'drawer' design a top-down or side view? I have a hard time imagining an ergonomic/comfortable table height where you can place components under the surface without colliding with your knees. Also I don't see any exhaust in the design?
This is a top viev, it will be placed on the right of the desk, shorter edge, to the wall, I won't have any problem with my knees coliliding with case because i newer seat at the right edge of my desk. It is like 1,8m? Exhaust will be between mobo and gpu, probably will have some smaller fans at the top of gpu and mobo but with this we wil see.
https://linustechtips.com/topic/973696-drawer-pc-project/#findComment-11770201
