Would this air cooling setup work efficiently?
30 minutes ago, TheOneLasagna said:
I’m building in the Fractal Design Meshify C and I have 2x 140mm fans as the intakes, two 120mm fans at the top as exhaust, and one 140mm fan in the back as exhaust. Would this cool a Gtx 1060 and a i5 8600k effectively?
yeah it'll be fine, you can even go without the two top exhaust fans and it would work (look up positive and negative air pressure aswell, not really a expert on it myself but i have more fans in than out)
2 hours ago, Firewrath9 said:
whats your CPU cooler?
  I'm using a hyper 212 evo to cool my CPU. It will be blowing towards the back exhaust fan. I just found out that my case will only allow a 120mm fan in the back so I'll probably just do that with one 140mm on the top and 2 140mm's in the front.
