Yesterday my friend was on my phone and all of a sudden it just turned off. Of course this freaked me out because the battery was at 60%. My first solution was to plug the phone in and see if i could force reboot it but this did not work so i left it plugged in and the battery got hot like it usually would. Seeing this I thought the screen was dead so i looked up how to fix that problem but after looking into it this did not seem to be the case. So i went back to the charger problem i tried three different outlets and 5 different charger for each no luck. What should I do to fix this.
https://linustechtips.com/topic/972427-pixel-2-xl-odd-problem/
24 minutes ago, Airdragonz said:
Is it detected by a computer? If not, attempt to restart it into fastboot/bootloader mode or recovery mode. Try to see if you can use adb or fastboot commands.
A computer doesn't detect it And as for the boot the phone screen doesn't display anything.
https://linustechtips.com/topic/972427-pixel-2-xl-odd-problem/#findComment-11757625
