Dead Hard Drive?
Go to solution Solved by kb5zue,
5 minutes ago, sprunk said:
Hi, I have bought a usb hard drive enclosure and was looking to use an old hard drive I had lying around for back ups.
Though when i connect it up the drive was recognized in windows though I couldn't write any files to it. I deleted all the partions on the drive in disk management and got it back to a raw disk though every time I try to reformat it I get an error message.Is there anything else to try or is it ready for the bin?
Thanks.
If you could give us a little more information it would really help.  What is the make and model of the drive?  How old is the drive?  What is the operating system you want to use with the drive?  Does the drive work if installed in the computer?  Did you recreate a new partition after deleting the original partition?
Thanks.
https://linustechtips.com/topic/972093-dead-hard-drive/
Thanks.
https://linustechtips.com/topic/972093-dead-hard-drive/#findComment-11754818
It's a western digital 1tb green drive. About 4 years old. Using windows 10. The drive has the same problem installed in the system. I created a new Partition after deleting the old one though it won't let me format the partition. I think the problem might be when trying to create a partition cause it seamed to hang for a bit.
https://linustechtips.com/topic/972093-dead-hard-drive/#findComment-11754845
Thanks.
Sounds like the partition didn't apply right. sometimes a HDD in a enclosure will not allow a partition with a normal windows tool. for future reference there is a dos/command line tool that you can even unlock partitions or lock them so they can't be deleted. it is called fdisk if I remember.
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
https://linustechtips.com/topic/972093-dead-hard-drive/#findComment-11756254
7 hours ago, STRESSMASTER said:
  Reveal hidden contents
fdisk stands (for “fixed disk or format disk“) is an most commonly used command-line based disk manipulation utility for a Linux/Unix systems. With the help of fdisk command you can view, create, resize, delete, change, copy and move partitions on a hard drive using its own user friendly text based menu driven interface.
https://www.tecmint.com/fdisk-commands-to-manage-linux-disk-partitions/
https://linustechtips.com/topic/972093-dead-hard-drive/#findComment-11757512
correct but it was in it's first life a DOS com file. It was used in windows 3.1 & 3.11 95 upto windows XP. MS integrated MOST but not all it's functions into the windows GUI when VISTA came out
https://linustechtips.com/topic/972093-dead-hard-drive/#findComment-11759988
