EVGA LED SYNC
Go to solution Solved by Z3R0 CHANC3,
Just remove XOC from startup programs.  The GPU should remember the RGB settings you previously set.  At least it does with my EVGA card.
I got a EVGA GTX 1070 FTW.  I downloaded EVGA Precision XOC to change the RBG settings.  The controls are fine, but now every time I start my computer windows asks if EVGA can make changes to my computer.  Is there any way to make it stop asking without changing change requests settings for all other programs?
https://linustechtips.com/topic/972072-evga-led-sync/
