Thermal Paste for CPU
Solved by Oshino Shinobu,
The difference between the best and worst is only a few degrees. If you're not overclocking, it's not worth spending money on aftermarket stuff. The TIM that comes with the CPU/Cooler is fine.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
4
play_circle_filled
Latest From ShortCircuit:
