I am wanting to do something with my old PC I built back in 2013. It has a Intel i5-4690k which has a LGA 1150 socket. The problem I am having is trying to fina mini itx motherboard with this socket and has wifi. If someone can help me out with this that would awesome! If not, what are some full atx cases that have small form factor, preferably a cube shaped case. Anything helps! Thanks!
https://linustechtips.com/topic/971756-help-finding-motherboard-or-case/
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
Full-size ATX cases do not come in small form factor. Small form factor is usually determined by the size of the motherboard (mATX or mITX). Since you are getting an mITX board, there is no point in buying a full size or even mid size tower. I think you are looking for something like a Thermaltake Core V21 or Corsair Air 240
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Let me clarify. I would prefer to find a mini itx or micro atx motherboard with socket LGA 1150 and wifi because I have already found a case in that size that I like. But I have not been able to find a motherboard in that size myself, so my second option would be to get a small full atx case and just use the atx motherboard I already have from my old PC. Small full atx case such as::
https://www.amazon.com/RIOTORO®-CR1080-Compartment-Support-Dedicated/dp/B01D205IXS/ref=sr_1_10?s=pc&ie=UTF8&qid=1471210680&sr=1-10&keywords="full+atx"
