I need some advice on upgrading my rig. Im changing from Intel Mobo and processor to AMD and I'm planning on getting a new SATA ssd since I need to reinstall the windows 10. Will it work if I install Windows 10 on the new SATA ssd then plug in my old SATA hdd? Do I still get to use my files in my old SATA hdd?
https://linustechtips.com/topic/970566-will-it-work/
Yep, if you install a new SSD and still plug in your old HDD, it should just show up in File Explorer like usual.
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
https://linustechtips.com/topic/970566-will-it-work/#findComment-11739807
just install windows on the ssd on the new amd rig. then back up the important stuff from the drive after that go to disk manager delete the 3 partions from the hdd then select the raw partition and format it as ntfs. finally, put all the stuff you backed up back
https://linustechtips.com/topic/970566-will-it-work/#findComment-11741997
