Hello,
I have a MSI GS73VR 7RF Stealth Pro pc. It has a Killer E2500 nic. When i try to connect with ethernet, it comes and then says cable is unplugged. Keeps doing it in a loop after that when i check it in settings page output/input packets count is changing like it's on overflow. Is it common driver bug or something else?
What i did before writing:
I uninstalled all drivers with Killer Uninstaller
Downloaded the newest driver from killer's website.
Installed it with no problem (wifi works flawlessly killer 1535)
Tested router and lan cable on other pc's
etc. etc.
It's very strange that a 2000$ machine has problems like this. It makes me sick :(
https://linustechtips.com/topic/970411-killer-e2500-issue/
Have you tried a different cable?  Install only the driver not the killer app?
https://linustechtips.com/topic/970411-killer-e2500-issue/#findComment-11742549
