I haven't seen any. But before i begin my google search i thought i would ask the community.
Anybody taken appart an AIO block to see what sort of design they are using to shed heat into the water?
I mean we all look at our custom blocks, some more sexy than others, and all the company's trying to one up each other in fin design, water flow direction, restriction, placement of inlet/outlet, (if you really care that is) and then we got our tops that provide more sexy, or performance, or nothing comparatively.
So have you see an exposed AIO base plate?
https://linustechtips.com/topic/968736-aio-blocks/
As far as I've been able to discern from transparent blocks, it's just a big windy tube to increase surface area. It would be impractical to add something like fins, which would add surface area but introduce turbulence, requiring a better pump. The milled surface of the metal would be enough to provide extra surface area while also allowing decent flow.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/968736-aio-blocks/#findComment-11722361
 I have now seen a nxzt kraken base plate, and a h70 base plate, both seem to use straightpass (top->bottom, L->R)   with what appears to be thin (estimated 4-7mm tall) die covering water placement, both with fins to add output presumably/channel water through the block to the outlet side.
those are the only two i have seen so far, one was just a picture, and the other was a h70 youtube disassembly
https://linustechtips.com/topic/968736-aio-blocks/#findComment-11722387
Gamers nexus have done quite a few of these disassemblies if you want to look for them. Usually most of the aio's share the same design (Aseteck is the biggest and most commonly used supplier) so once you see the one disassembly you've seen them all. The only thing different would be the PCB to control the rgbs or the temp monitors.
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/968736-aio-blocks/#findComment-11722541
Thanks for the info and reply.   i will check them out when i got some more spare time.
I was just curious, I guess it makes sense that they most use the same specs. Just like most rebranded pumps are nearly identical in the end.
https://linustechtips.com/topic/968736-aio-blocks/#findComment-11722569
