Any more information you can provide?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/968457-pc-boot-up-problems/#findComment-11719745
Need more details. Specs for example
Also exactly what does the system do each boot attempt? Do any LEDs flicker in a different fashion than that of working boot or normal?
Main system "Kethlon":
Core i7 3820 - Intel Desktop Board DX79TO - 32GB 1600MHz DDR3 RAM Dual channel - EVGA GTX 1050 Ti SSC - EVGA 550 B3 - PNY 120GB SSD (boot),WD Blue 1TB (Mass Storage)
See profile for full specs
Primary Laptop "Vengeance":
HP HDX16 1370US - Intel Core2Duo P8700 - 4GB DDR2 800MHz RAM Samsung - HGST 1TB 7200RPM (Windows 7, Linux, MacOS 10.11.6) - Nvidia GT 130M 1GB DDR2
Downed Laptop "Xarasky":
MacBookPro3,1 - Core2Duo T7700 - 4GB DDR2 RAM 667MHz - Nvidia 8600M GT 256MB VRAM - 640GB HDD (MacOS and Windows)
Testing laptop #1 "Leonard":
HP 15 F387WM - AMD A8 7410 APU - 8GB DDR3 Samsung RAM 1600MHz - AMD Radeon R5 graphics (1GB VRAM partitioned out of physical RAM) - 500GB WD Blue mobile drive
https://linustechtips.com/topic/968457-pc-boot-up-problems/#findComment-11719748
Try this:
whenever you know the PC is going to do a false boot (which you seem to know), switch off the power supply, then switch it back on.
20 minutes ago, ArkhamGaming said:
Also it would be nice if you can send me a compatible ssd that is 128g.
who is sending who an SSD? are you getting a new one?
Primary PC:
PSU tier list
https://linustechtips.com/topic/968457-pc-boot-up-problems/#findComment-11732420
14 minutes ago, ArkhamGaming said:
yes im getting a New SSD and if you can find a 128g ssd that is compatable to my pc please send a link
Any SATA SSD is compatible. If you've got a SATA cable you can plug it right in.
Primary PC:
PSU tier list
https://linustechtips.com/topic/968457-pc-boot-up-problems/#findComment-11732674
