Water Cooling Question
Solved by mikedrewsmy,
18 minutes ago, Hi P said:1.- Generally speaking, is water cooling a waste if the CPU and GPU won't be O.C?
2.- If I don't plan to O.C would Air be okay?
3.- Would leaving a computer doing 3D rendering for hours require water cooling or not really?
Thanks!
Which processor will u be using?
Mostly would be fine with air cooler, just make sure the ambient temp isn't high.
