laptop apu problems
Go to solution Solved by bransasko,
thank. but my bios doesnt have that menue or setting. its very locked down.
I think it can't be increased.
Or it is the maximum memory for labtop apu
As we all assumed that the labtop apu and pc apu are the same.
I whish i can help more.sorry
Hello, i like to say first that ive enjoyed gaming on my asus K55N laptoop. But i would like to allocate more memory toward my apu which is a Amd A8-4500m. Right now i only have 512mB of ram allocated and i cant change it in the bios. I would like to know if theres any way around this so that i can at least allocate 2 GB of ram. I currently have 8 GB of 1866MHz ram and only use at most 5 GB. Can anyone please make any suggestions to do this? thank you.
https://linustechtips.com/topic/96758-laptop-apu-problems/
Pretty sure you can only do it through the BIOS.
what is your OS and what bit rate does it run at?
Guessing how long it is taking you to respond, you do not even know...
Your wording is confusing and he could be offline.
https://linustechtips.com/topic/96758-laptop-apu-problems/#findComment-1294716
i bassiclly want to allocate more ram for my gpu but my bios wont let me.
You would have to modify the bios using a hex-editor if you want to change values that are locked.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
https://linustechtips.com/topic/96758-laptop-apu-problems/#findComment-1296100
I read some thing about APU shared memory
That the shared memory depends on the system memory.
It was in a table on a 6670 video card unboxing.
As remember if the system memory 4 gb the maximum shared is 1 gb(for pc)
So i think the solution in upgrading system memory
https://linustechtips.com/topic/96758-laptop-apu-problems/#findComment-1296338
how and where do you get hex-editor. Also is it safe to use?
It is not safe to use. I would recommend against it. Also, some BIOSes are encrypted. But if you really want to do it:
https://www.google.com/search?q=bios+mod&oq=bios+mod&aqs=chrome..69i57j69i59j69i65j69i59j69i60l2.1828j0j7&sourceid=chrome&espv=210&es_sm=122&ie=UTF-8
https://linustechtips.com/topic/96758-laptop-apu-problems/#findComment-1296407
I was just wondering if there was some way around the os to do it. i would prefer not to do it see as its not safe but thank you anyway.
https://linustechtips.com/topic/96758-laptop-apu-problems/#findComment-1296415
If found this tips in my friend's mb.and we apply this tip to make the shared ram 1gb
Enter BIOS Setup to set the following items under the Peripherals\GFX Configuration menu:
- Set Integrated Graphics to Force.
- Set UMA Frame Buffer Size to 512M or above.
https://linustechtips.com/topic/96758-laptop-apu-problems/#findComment-1296443
If found this tips in my friend's mb manual.and we apply this tip to make the shared ram 1gb
https://linustechtips.com/topic/96758-laptop-apu-problems/#findComment-1296448
https://linustechtips.com/topic/96758-laptop-apu-problems/#findComment-1296459
