As a (relative) newb to MacOS x on a system, I am none the wiser as to what alternatives there are for progerams that I am familiar with and use within windows and this, fellow forum members, is where I need some help.
I am looking for the Mac alternative of the following programs and all help, pointers, information will be much appreciated.
What are the Mac alternatives to:
Programs:
Speccy
Recuva
MS Office
Serif WebPlus x8 (i know, it's old but I prefer this version)
Chirp (Amateur/Business radio programming software)
Audio/Video Tools
K-LiteCodec Pack (Audio/Video codecs) (Will I actually need it?)
I think I will leave it at that for now.... I have a long list to go through but I have already found some alternatives to my "must have" programs/add-ons/tools.
Instructions ? WHAT?!?!?! A man don't need instructions!       Oh............wait a minute...........................What's this bit for?  aaaaaagh!!
Vita imitatur artem, imitantur vitae
Lenovo M73 10AXS38G00 i7 4785T 2.20GHz, 16GB Ram, WD Black2 1.2TB Dual Drive, W7 64bit Ultimate, Lightscribe mulit-write Optical.
Lenovo M73 10AXS06G02 G3220T 2.6Ghz, 6GB RAM, 320GB HDD, W7U, Stock DVD Optical
Lenovo T420 42369N8, i5 2520M 2.5/3.2GHz, 16GB Ram, 256GB SSD (iOS 10.13.6 High Sierra), 750GB WD HDD (W7 Ultimate) Dual Boot, Lightscribe mulit-write Optical.
Lenovo L412 4403CT0, i5 520M, 2.4Ghz, 6GB RAM, 320GB HDD Win7 Ultimate Stock DVD Optical.
Custom (re)Build Tower (WIP). Asus Prime B350 Plus Mobo, GTX 960 GPU, Custom MOD Watercooling, Gamemax Falcon Case (two windowed side panels), RGB fans, dual rad CPU loop with 240 & 280 Rads, 120 GPU Rad. RGB Fittings, RGB & BL case lighting. Custom acrylic internal shields/shrouds. Remainder TBD.
https://linustechtips.com/topic/967573-help-mac-os-programs/
Install windows.
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
https://linustechtips.com/topic/967573-help-mac-os-programs/#findComment-11711413
Just now, williamcll said:
Install windows.
Just how is that helpful?  Seriously, how is that helping?? Explain to me, in detail, how that answer helps???
If you want to troll, go elsewhere please.
I have a dual-boot system with MacOS as the master OS and Win7U as the secondary. I am in a situation that I need to run and learn about MacOS, hence my OP.
https://linustechtips.com/topic/967573-help-mac-os-programs/#findComment-11711422
If you’re okay with paid,
Microsoft does have word for Mac
otherwise you can use Libre office which is one of the most popular open source office programs.
Mac OS has “time machine” which is sorta like recuva.
Here are some alternatives
https://formac.informer.com/search/?q=Recuva
I don’t know many of the other software and I’m on mobile but that should get you started at least.
Apple has a lot of built in programs like movies, GarageBand & more. They are really easy and really powerful.
Edit:
programs apps and websites section has a pinned thread about free and open source alternatives to popular programs.
https://linustechtips.com/topic/967573-help-mac-os-programs/#findComment-11714651
Thanks for the reply and the information.
I had not realised and thus was not aware of the pinned thread you mention as I am still "finding my feet", as-it-were, with this forum.
https://linustechtips.com/topic/967573-help-mac-os-programs/#findComment-11714718
