Mobile data won't work on Redmi Note 5. Dual SIM card slot. Two different network SIMs used. Neither works with mobile data. Tried rebooting phone. Don't have another phone to try SIM in
CPU: Intel Core i5 4690 3.5GHz
Motherboard: Asus Z97-P DDR3 ATX
RAM: Kingston HyperX Savage 8GB 2400MHz
GPU: Palit Geforce GTX 1060
Case: Zalman Z9+
Storage: Seagate Barracuda 2TB 7200RPM HDD, SK Hynix 256GB SSD
PSU: SuperFlower Golden Green HX 550W
OS: Windows 10 64-Bit
https://linustechtips.com/topic/967082-redmi-note-5-mobile-data-not-working/
when setting up a mobile not provided by your network you sometimes have to manually enter network info to get data to work.
search for:
'your mobile network' mobile data settings
then enter the settings here:
setting > more / mobile networks > access point names
click the + top right and enter the setting you find online. if your not told a setting leave the default setting, or if its blank leave it blank.
search for:
As soon as I change the MNC the access point gets deleted
Case: Zalman Z9+
Figured it out. The APN was the problem, and it only looked like it was being deleted because I had the wrong SIM set to the default for data so when I changed it back all my previous attempts at APNs appeared
Case: Zalman Z9+
