I had some encrypted files on "D" partition of HDD. But i had my computer's "C" partition formatted. So now i still have those encrypted files on my computer but when i try to open it, it says access denied or unable to open. I think this might be due to erasing of decryption keys. Is there any way to decrypt them.
https://linustechtips.com/topic/966988-need-help-in-decryption/
Not really, unless you have the keys if you are using any kind of new encryption.
You would need massive amount of computational time to even scratch the surface of whats encrypted.
Unless you have a security insider that knows of a backdoor.
https://linustechtips.com/topic/966988-need-help-in-decryption/#findComment-11706284
