hey folks, i have an old Dell Latitude E6520 laptop that supports raid and i'm trying to set up raid 1 on. I've updated the bios (A21) and changed the sata operation mode to raid in the bios. However the only option i get in the raid setup boot screen is "recovery" i've also tried to set it up in windows in intel rts but i get the same there anyone know why i'm not getting any other options, appreciate any help cheers.
https://linustechtips.com/topic/966053-help-with-raid-setup/
3 minutes ago, Nazarah24 said:
2 kingston UV500 2.5 250gb ssd's
It seems like there should be a SATA mode called RAID On in the BIOS. Can you see that?
When booting, you'll get the RAID splash screen/menu where you can press Ctrl+I to enter it. Do you see both drives there or just the one?
https://linustechtips.com/topic/966053-help-with-raid-setup/#findComment-11697414
1 minute ago, Nazarah24 said:
yeah raid in enabled in the bios and in the raid splash screen it see's both drives i just can make any raid other than "recovery"
Strange. You could always set it up in Windows Disk Management. As it's RAID 1, you should still be able to boot from it when it's software RAID. Won't tie you to the board either.
https://linustechtips.com/topic/966053-help-with-raid-setup/#findComment-11697421
true but i want to dual boot linux as well
Not sure on that then. If the drives are showing on the initial RAID menu, they should be available to add to an array.
I've not come across it only showing recovery before. Maybe try going though the recovery mode to see if options come after after going through it.
https://linustechtips.com/topic/966053-help-with-raid-setup/#findComment-11697430
i tried my luck with dell support and they said since it's a out of warranty product they can't offer free support,so basically pony up if you want help lol
Pretty standard for tech support, even if it's just a question :D
Having a redundancy drive may be the best you can get out of it. Worth testing to see if striped reads works with it or not. They may just not call it RAID 1.
https://linustechtips.com/topic/966053-help-with-raid-setup/#findComment-11697460
so i gave up after the linux install had issues with the other partitions and just imaged the windows install and formatted everything then installed linux using software raid 1. I don't need dual boot it was just to make it easier if i wanted to switch back at some point but if i ever need to switch back it will be because i no longer need the linux os so shouldn't be a problem wiping then. Thanks for the help though ;)
https://linustechtips.com/topic/966053-help-with-raid-setup/#findComment-11698417
