So throttlestop randomly stopped working and this is the error i get every time now when trying to open TS "WinRing0.dll was not found" Really need to figure out a fix for this to cool down my cpu.
Dell G7 - Win10 (GTX 1060 Max-Q 1,874mhz / I7 8750H 4.1ghz / 16GB 2666mhz DDR4 / 128gb SSD / 1TB HDD) overclocked and undervolted.
Cinebench Scores                            Unigine Valley Ultra Benchmark
OpenGL:    110.78 fps                       FPS: 73.6
Cpu:           1236cb                            Score: 3080
singlecore: 173cb                              Min FPS: 33.5
MP Ratio:   7.14x                               Max FPS: 151.3
                                                          1874 Mhz gpu clock
                                                           63 deg C stable
https://linustechtips.com/topic/965969-issues-with-throttlestop/
What antivirus program are you using?  Windows Defender likes to randomly put ThrottleStop on the bad list.  I use the free version of Avast Antivirus and never have issues like this.
Try starting OpenHardwareMonitor first and then try to start ThrottleStop.  OHM uses the same WinRing0 driver so once it starts, ThrottleStop can usually tag along for the ride.
https://openhardwaremonitor.org/
TY this worked.
                                                          1874 Mhz gpu clock
                                                           63 deg C stable
  • 1 year later...
