Hi, I would like to consult my rig, I just recently built my own pc but i notice it's grounded i properly put the mobo stand off. When i plug it directly my PSU(seasonic sii 520watts) to our outlet it grounds my unit. I did purchase an AVR and it was fix. Do you think this is right thing to do? please help. I'm from Philippines.
https://linustechtips.com/topic/965951-grounded-unit-pc/
If you want to ground yourself using a PSU it requires nothing but a outlet and a PSU. Don't turn your PSU on and plug it into a outlet. And then slap your PSU everytime you want to install something.
With Great Power, Comes a Great Electricity Bill
Main
Setup: Intel core i5-8400 (OC'd), MSI Z-370-A Pro, Crucial Ballistix 8GB, Be Quiet! Pure Slim, Cooler Master Masterbox Lite 5 RGB, TP-Link Wifi Adapter, ASRock RX580, Artic Silver 3.5g Thermal Paste, Logitech G105, Logitech M310, Razer Sphex V2 (Mat), EVGA 500W 80+ Silver, 1TB WD Blue, 240gb Kingston Digital
https://linustechtips.com/topic/965951-grounded-unit-pc/#findComment-11696490
I did have good psu(seasonic sii 520watts) though. But i suspect my mobo is static. Right now didn't feel anything even a small static or ground when i connect it avr to my psu.
https://linustechtips.com/topic/965951-grounded-unit-pc/#findComment-11696507
Encountering static contact is pretty rare (to say the least in my experience building for 4 years) so normally when you touch a static device it wont shock you or anything. It just grounds yourself. You wont get shocked when you slap your PSU either. But either way. If it's connected to a outlet. And you touch that it will still ground you. That's why people use anti-static bracelets. Because it wont shock you for the duration of the build. If you are carrying a crap-ton of static in your body. You might feel a minor shock. But nothing else.
Main
https://linustechtips.com/topic/965951-grounded-unit-pc/#findComment-11696517
