Remote Graphics?
Go to solution Solved by Zagna,
It is meant to used by having it running in a server and then with that ethernet port, connect it to a PC-over-IP (PCoIP) client, a small box with usb and display outputs.
The server does the computing, the PCoIP box only receives the compressed video and displays it.
https://linustechtips.com/topic/964813-remote-graphics/#findComment-11686168
