Case fans
Go to solution Solved by emosun,
3 minutes ago, RandomGu123 said:
Should I be worried?
no
I don't know if it should go here on Air Cooling but anyways..
I bought a used PC and It has 3 fans, 2 at the front for intake and 1 in the back for exhaust, both of my front fans are supposed to have LEDs but only one has them working.
I wasn't too worried though as its only some glow however, when I was doing a cinebench run I went on HW monitor and realised there were only 2 case fans recognised, I went to BIOS, same only fan 1 and 2 recognised, after some digging I found that the fan that isn't glowing is plugged into fan 3 and isn't recognised, however it is still spinning
Should I be worried? I mean the fan does still work
https://linustechtips.com/topic/964763-case-fans/
