So I am an avid aeroplane spotter and have always used my default 18-105mm lens with my Nikon D3200, For long range pics at the airport though with distances in excess of 3km the digital cropping is not enough. I am trying to buy a lens but I am not really sure what to expect or how they perform, I normally shoot in broad daylight and don't care much about "bokeh". I also use autofocus for fast moving situations and the default Nikon 18-55 lenses seem really slow.
I have a very very tight budget of 150-200€ MAX and I am looking for used 300mm lenses.
Here are a couple I have found on a Spanish used item website that  I can probably reduce the price on.
https://es.wallapop.com/item/objetivo-tamrom-70-300mm-183509660
https://es.wallapop.com/item/objetivo-fotografia-180553245
https://es.wallapop.com/item/tamron-28-300mm-255346867
https://es.wallapop.com/item/objetivo-sigma-dg-70-300-146239408
https://es.wallapop.com/item/objetivo-sigma-70-300-apo-dg-macro-f4-5-6-nikon-255516685
https://es.wallapop.com/item/nikon-dx-vr-af-p-nikkor-70-300mm-1-4-5-6-3g-ed-236117166
Thanks!
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/964538-lens-help/
