This build os for gaming and editing mainly as well as media streaming.Any suggetions for mobo or any other part for better value?thanks.
LG - 27UK650-W 27.0" 3840x2160 60Hz Monitor
Microsoft - Windows 10 Home OEM 64-bit
EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Fractal Design - Meshify C Dark TG ATX Mid Tower Case
Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory
Asus - TUF H370-Pro Gaming (WI-FI) ATX LGA1151 Motherboard
CRYORIG - H7 Quad Lumi 49.0 CFM CPU Cooler
Intel - Core i7-8700 3.2GHz 6-Core Processor
https://linustechtips.com/topic/962899-building-my-first-pc/
A GPU would be nice.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/962899-building-my-first-pc/#findComment-11668563
1 minute ago, Gamerfiend_ said:
I can second this information regarding Seagate drives, I had one fail when it was treated with nothing but care, also check Ebay for Windows Keys, you can download the OS for free & get a code for around £5.00 (Im in England UK)
I work in company where we process a lot of high capacity drives and we ditched seagates for WD only
https://linustechtips.com/topic/962899-building-my-first-pc/#findComment-11668651
4 minutes ago, liakouri094 said:
No problem with bugdet.Ill spent around a 1,000 euros but i can spend more if i get them one by one and not all together
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  (€188.00 @ Amazon Deutschland)
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard  (€89.49 @ Mindfactory)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory  (€141.89 @ Mindfactory)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  (€89.90 @ Amazon Deutschland)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (€58.55 @ Amazon Deutschland)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Dual Video Card  (€269.00 @ Amazon Deutschland)
Case: Cooler Master - MasterBox Lite 3.1 MicroATX Mid Tower Case  (€40.69 @ Amazon Deutschland)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (€85.99 @ Amazon Deutschland)
Total: €963.51
Generated by PCPartPicker 2018-08-21 18:18 CEST+0200
something like this would be a good buy. if you had used something else than the Adobe suite id pick something else
https://linustechtips.com/topic/962899-building-my-first-pc/#findComment-11669505
Total: €963.51
Thank you very much for your time and the answer .Much appreciated.One last question will i5 be adequet?
https://linustechtips.com/topic/962899-building-my-first-pc/#findComment-11670144
it shhould be good enough. its not the best, but you cant get much better without going over budget. though i can try, but you will be skimping on some stuff
https://linustechtips.com/topic/962899-building-my-first-pc/#findComment-11670156
