Need driver help
Go to solution Solved by HolaImBob,
4 minutes ago, The Cheeto Bomb said:
ok. but how/where do I install these drivers?
once you have downloaded them, you might need to unzip or unrar them, use win rar to extract them.
open the .exe files and follow the steps in the installer. some of them will need you to restart your pc.
Threw this together last night:
r3 2200g, b350m mortar, 2x4gb crucial oc to 3200, sp ssd, toshiba hdd, windows 10 home,
I need help with installing/updating drivers. what ones do I need? were do I get them?
Main pc
CPU: AMD RYZEN 2200G || GPU: EVGA GTX 780 || PSU: EVGA 500W  ||  MOBO: MSI B350M MORTAR ||
RAM: BALLISTIX SPORT LT 12GB (4X3) DDR4 3133 MHz ||  CPU COOLER: AMD WRAITH STEALTH || SSD: SILICON POWER S55 120GB (BOOT) ||
HDD: WESTERN DIGITAL 500GB BLUE 7.2K RPM, 200GB random Toshiba HDD || CASE: Thermaltake View 28 ||
Consoles
|| XBOX 360 || NINTENDO WII U || PLAYSTATION 3 || PSVita (1000 model, henkaku fw 3.87 || NINTENDO 3DS XL || Nintendo Switch Lite ||
https://linustechtips.com/topic/962700-need-driver-help/
Main pc
Consoles
https://linustechtips.com/topic/962700-need-driver-help/#findComment-11666539
1 minute ago, HolaImBob said:
pretty much
you could also update the bios
Main pc
Consoles
https://linustechtips.com/topic/962700-need-driver-help/#findComment-11666703
https://linustechtips.com/topic/962700-need-driver-help/#findComment-11666728
just figured that out before you posted sorry.
Main pc
Consoles
https://linustechtips.com/topic/962700-need-driver-help/#findComment-11666736
