This will be my 2nd build so at first I thought it would as easy as the first. Then I realized I built my first 5 years ago and when I started watching LTT again so much more tech has come out and changed. Instead of doing all the research myself, what would an experts perfect $1000 build be right now. I know Linus has a video but it is sponsored and I know you can make a better PC than that for $1000. Only requirements are a full see through panel on the case and its ability to run any game I choose with ease. I fully water cooled the last one and plan on doing any water cooling on this one. Just looking for some help especially in the GPU department. My last build was AMD so I want to try Intel this time. THANKS!
https://linustechtips.com/topic/962151-2nd-pc-build-help/
Check out this build: https://pcpartpicker.com/list/nGxwyX
You can bring down the cost to $1000 USD by removing the aftermarket CPU cooler and buying a cheaper motherboard, but I feel that this build gives you a solid upgrade path for the future. This PC should be able to run any game at 1080p high-ultra settings with ease, and it also looks pretty good IMO.
Of course if your build is ONLY for gaming, you can get better performance by buying a better GPU, buying 8GB of RAM instead of 16GB, buying a cheaper motherboard and case, etc.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/962151-2nd-pc-build-help/#findComment-11661132
