Help! 700 USD Gaming pc
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($149.99 @ Walmart)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($69.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory ($89.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive ($64.99 @ Amazon)
Video Card: Asus - Radeon RX 580 8GB DUAL Video Card ($239.99 @ Newegg)
Case: Cooler Master - MasterBox Lite 3.1 MicroATX Mid Tower Case ($35.98 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($58.98 @ Newegg)
Total: $709.90
Generated by PCPartPicker 2018-08-19 04:25 EDT-0400
Its a little over budget, but a great valuebuild.
Since you might not buy from the sites above ill give some advice.
For the GPU you will look for the Cheapest RX 580 8GB OR GTX 1060 6GB (pay attention to the Vram amount especially on the GTX 1060 as the 3GB model is significantly slower). Pick whichever of the two are cheaper. Also avoid the card if its cooler is made by ASrock or is named "armor".
For ram you want the cheapest 2 sticks of 4GB DDR4 3000mhz or 3200mhz memmory.
If you have any questions just quote me or @GoldenLag me
