i just bought a new Kingston UV400 SSD. And replaced my laptops HDD with My new SSD. After 2 months it Suddenly Stop recognizing in boot menu. So i removed it and putted it in enclosure and plugged it in to another computer, but it still wasn't  been detected by the computer. what can i do to fix this ? pls HELP
https://linustechtips.com/topic/962034-kingston-uv400-problems/
Just send it in under warranty
otherwise try testdisk
or depending on your retailer you might just be able to return it
https://linustechtips.com/topic/962034-kingston-uv400-problems/#findComment-11660226
