Simple Volume or primary partition??
Go to solution Solved by Master Disaster,
Just now, rosankarel said:
so there will be no problem if i keep my files in that volumes ?
It should be totally fine :)
Hi there , tomorrow i inserted my old seagate 500 gb hard drive to my other pc and all things is working fine
but the hard drive is labelled as simple volume and not primary partition.
i dont know much about storage devices is there something to worry about???
https://linustechtips.com/topic/960803-simple-volume-or-primary-partition/
No, any partition that has been formatted becomes a volume.
Main Rig:-
Server:-
Main Rig:-
Server:-
