25 minutes ago, wONKEyeYEs said:
Faulty fan?
Did you try a working fan off that fan header
or try the nonworking fan on another header?
On my previous asus mobo, it worked just fine. I did have to unscrew the fan inorder to reach the cpu power pin and screw it back into place when i replaced it with an msi board, so maybe thats what messed it up?
https://linustechtips.com/topic/960298-case-fan-wont-spin/#findComment-11645486
27 minutes ago, wONKEyeYEs said:
Faulty fan?
Il buy another 120mm fan and plug it into the fanheader in question to see if it works. Are there any good budget 120mm fans u reccomend?
https://linustechtips.com/topic/960298-case-fan-wont-spin/#findComment-11645495
1 minute ago, wONKEyeYEs said:
Regardless,
My board only has 2 headers, a sysfan and cpufan. My case fan is a 3 pin and the pins for sysfan are 4 pin. Would that make a difference?
https://linustechtips.com/topic/960298-case-fan-wont-spin/#findComment-11645506
OK, this means that you have a CPU fan and at least two other fans.
So if you have all these fans you must be using a splitter.O.o
The MB fan headers with 4 pins will accept a 3 pin fan no prob.
Best to keep the CPU fan in the CPU MB header.
Well, all the other fans not counting the cpu and chasis fan dont connect to a mobo
https://linustechtips.com/topic/960298-case-fan-wont-spin/#findComment-11645528
