Hi,
I have been troubleshooting this program (written in python) for a while. I expect the water texture to be in the top left corner of the window, but it's just a blank screen.
I'll include a link to the folder that the program is in rather than copying the code because there are a few other files in it.
https://drive.google.com/drive/folders/1q_j4fd51ZiLaU_hDeHbHWDIoxOUKrlWW?usp=sharing
Thanks for your help.
https://linustechtips.com/topic/959994-pygame-issue/
You specified a height and width of 0 for your map surface.
Give it the same height and width as your window (or whatever you want), and you should see the texture.
Surface syntax: Surface((width, height), flags=0, depth=0, masks=None) -> Surface
#Size currently set to 0x0
mapsurf = pygame.Surface ((0,0), pygame.HWSURFACE | pygame.SRCALPHA)
#Size same as window
mapsurf = pygame.Surface ((800,600), pygame.HWSURFACE | pygame.SRCALPHA)
https://linustechtips.com/topic/959994-pygame-issue/#findComment-11645530
Thanks very much.
https://linustechtips.com/topic/959994-pygame-issue/#findComment-11649112
