Hello,
I need some advice to clarify some points. I'm looking for a new IPS monitor around 200€ to replace my 24" IPS LG and my choices are pretty limited (i live in Reunion Island and a lot of websites, such as Amazon, don't ship here). On the website I usually buy computer stuff on, I found an AOC PDS271 (https://www.amazon.com/AOC-PDS271-Designed-Porsche-1920x1080/dp/B073PFJ4JJ) and I felt in love with it ! It is a very gook looking monitor, and I'm a carguy, so Porsche, you know ! Haha !
Anyway, according to TrustedReview and TechAdvisor, it is a decent IPS monitor with good colors. But, I do have two questions :
1. Is AOC a good monitor brand ? I don't really know if any brand outside of LG and Samsung is good.
2. Does 27 inches make Full HD images look a bit weird and not sharp ? Should I grab the 24" one ?
It will be used for photo processing, video editing and watching movies. Do you really notice a difference between 24 an 27 inches for the same FHD resolution ?
Thank you for your time, I appreciate it !
MSI B650i Edge Wifi - Ryzen 5 7600 - 32GB DDR5 - EVGA GTX1060 6GB SC
https://linustechtips.com/topic/959847-27-inch-for-full-hd/
I would say 1080p max. 24" and 1440p max. 27". 1080p looks as you already mentioned not that sharp on 27". Maybe just get a 24" screen instead or go higher with a WQHD (1440p) monitor.
And yes, AOC is alright, but I'm not sure if this is good enough for editing. What is your budget?
edit:  I would recommend for 24" a Dell U2415 WUXGA (1920x1200), because I know that this is a good one. I can't say if this specific AOC monitor is good. And 27" WQHD (2560x1440) I know that those are pretty good: HP Pavilion 27q and Iiyama ProLite XUB2792QSU. Maybe one of them will be available for your location and fit in your budget.
https://linustechtips.com/topic/959847-27-inch-for-full-hd/#findComment-11641363
1080p at 27" looks a bit not-sharp, I'd really recommend 1440p for desktop use at that size, or if you'll be gaming get a 24" 144HZ 1080p panel
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/959847-27-inch-for-full-hd/#findComment-11641494
This ^^^ I play on a 24" 1080p screen, that's about the limit for 1080p IMO. 27" looks much to pixelated IMO (but then I work on an iMac 5K which is also a 27" screen). Personally I'd like a 24" 1440p display or 4K for 27", but then I like my super sharp eye candy.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/959847-27-inch-for-full-hd/#findComment-11641519
This, totally agree.
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/959847-27-inch-for-full-hd/#findComment-11641523
Honestly if you're going for just photo editing and movies I don't know why you'd want a 1080 monitor.
But, you might also want to consider VESA mounts, since if you have the space (and your photo editing n such) 2 monitors is at least twice as good as one you might want to stick them together somewhat.
#Muricaparrotgang
https://linustechtips.com/topic/959847-27-inch-for-full-hd/#findComment-11641560
Thank you for your answers, so I can forget about a 27" at 1080P !
About this particular screen, I saw 3 reviews of it saying it's ok, for example : "We certainly weren’t expecting 100 percent of sRGB and 87 percent of Adobe RGB gamut, a colour performance that many screens sold for professional use might consider offering." from TechAdvisor.
About the Dell, a friend of mine recommended the exact same one to me. I guess I'll try to look if I'm able to find one here ! :)
https://linustechtips.com/topic/959847-27-inch-for-full-hd/#findComment-11642338
27" for 1080p is totally fine, I used it for years and don't have any problem with it. AS LONG AS you keep your distance from your monitor at least 70 cm or more, if you like to sit closer than that you will feel like the texts are pixelated. btw 1440p for 27" is much better ofcoz.
AOC PDS271 is very overpriced (by the word porsche..) with that price you can get something like Acer G257HU which is 1440P IPS, more convenience for large photo editing.
Or if you really wanna stick to the luxury design, then get either Asus MX279H if you want 1080p or Asus VZ27VQ for 1440p. both of them are better than AOC PDS271.
Primary PC
CPU: AMD Ryzen 7 5700X3D | GPU: Zotac RTX 3080Ti 12GB | M/B: Asus ROG Strix X370-F | RAM: Corsair Pro SL 3200MHz 32GB | SSD: WD Black SN7100 1TB / Samsung 870 Evo 1TB | HDD: Seagate EXOS X16 16TB x2 | Power: Corsair RM850e | Sound card: Creative Sound BlasterX AE-5  | Case: NZXT H500 | Cooling: NZXT Kraken X62 | Display: Samsung QLED 27" 2K 144Hz VR: Pico 4
Secondary PC
CPU: AMD Ryzen 5 5600 | GPU: Asus RTX 4060 8GB | M/B: Asrock B450M Pro 4 | RAM: HyperX Fury 3200MHz 32GB | SSD: Crucial P1 1TB | HDD: WD Black 1TB | Power: Coolermaster Masterwatt 550 | CaseAerocool Cylon Mini | Cooling: BeQuiet Pure Rock Slim 2 | Display: Samsung QLED 24" FHD 144Hz VR: Meta Quest 2
Thanks for reading
https://linustechtips.com/topic/959847-27-inch-for-full-hd/#findComment-11642356
