Hey!
https://uk.pcpartpicker.com/list/2s6cRJ
Creates a quick set up (link above) for a friend for a work pc to run programmes such as 3ds max and revvit. Now I've not been up to date with hardware for a while so looking for any advice.
Budget is roughly£600 any cheaper would be a bonus.
Cheers!
https://linustechtips.com/topic/958116-work-pc-build/
1 minute ago, abdul94 said:
Hey!
Cheers!
a coffeelake i5 does better for revit and 3dsmax, so get that instead.
https://linustechtips.com/topic/958116-work-pc-build/#findComment-11627474
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  (£149.99 @ Overclockers.co.uk)
Motherboard: Gigabyte - H310M S2H Micro ATX LGA1151 Motherboard  (£49.54 @ Aria PC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  (£129.99 @ Amazon UK)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  (£51.59 @ Aria PC)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£32.39 @ Aria PC)
Video Card: PNY - GeForce GTX 1050 2GB Video Card  (£109.45 @ Amazon UK)
Case: CiT - CIT-F3BLACKRED MicroATX Mini Tower Case  (£26.99 @ AWD-IT)
Power Supply: be quiet! - Pure Power 10 CM 400W 80+ Silver Certified Semi-Modular ATX Power Supply  (£45.48 @ Ebuyer)
Total: £595.42
Generated by PCPartPicker 2018-08-09 13:34 BST+0100
https://linustechtips.com/topic/958116-work-pc-build/#findComment-11627485
Total: £595.42
Cheers will take a look at this list shortly. Appreciate it
https://linustechtips.com/topic/958116-work-pc-build/#findComment-11627695
