I'm looking to build my first computer. But I'm not sure what my priority should be, (i.e cpu, or gpu) for what the computer will be mainly used for. I want something that runs fast, and powerful. Light gaming, but mostly media streaming and transcoding. I want to be able to run Plex, in full 1080p, on multiple devices, without a hitch in rendering, while also using the computer normily, without it slowing down. I'm sure RAM also plays a part in all of this.
https://linustechtips.com/topic/958099-building-a-pc-for-streaming-plex/
What is your budget?
Will you be watching plex off your network? (ie someone in a different household watches it) because that's where the powerful cpu matters. otherwise your streaming it straigght from you storage computer without much transcoding
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
Mostly within my network. But my sister occasionally streams my content at her house as well. And I sometimes go to my brothers to hangout and watch a movie.
I'm usually watching stuff on it, while my kids are also using it. Right now, I'm using a qnap to stream everything. It doesn't do well with 1080p content streaming at the same time.
3 hours ago, kodiak211 said:
I'm not trying to go so out, but also not trying to be cheap either. At most, $2,000.
For streaming, you need cpu cores and a  gpu I assume you want storage so ill put a 16tb raid array  and an ssd and 10gb ethernet.
PCPartPicker part list: https://pcpartpicker.com/list/ZQzytg
Price breakdown by merchant: https://pcpartpicker.com/list/ZQzytg/by_merchant/
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor  ($239.99 @ Newegg)
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler  ($83.65 @ Newegg)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($131.49 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($149.99 @ Newegg)
Storage: Western Digital - Black 512GB M.2-2280 Solid State Drive  ($157.89 @ OutletPC)
Storage: Western Digital - Red 4TB 3.5" 5400RPM Internal Hard Drive  ($119.99 @ B&H)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($399.99 @ Amazon)
Case: Corsair - 750D ATX Full Tower Case  ($139.99 @ Newegg)
Power Supply: Corsair - TXM Gold 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $1852.94
Generated by PCPartPicker 2018-08-09 20:11 EDT-0400
I put a 1800x instead of a 2700x as the 1800x is 100$ cheaper and less than 10% worse.
Total: $1852.94
Great suggestions my brother. I think I'm going to go with the AMD 1800X. Question, is the motherboard you suggested future proof that you know of? Meaning, can I sometime in the future upgrade the CPU, or any other component if needed. I mean, I'm hoping to get a long life out of whatever I build, without having to upgrade anything.
The mobo should be future proof for a while now, AMD plans to support it through 2020 which is after 7nm so you should be fine.
https://hothardware.com/news/amd-confirms-am4-socket-support-future-ryzen-processors-2020
