Ok folks, new user here been a lurker for some time but finally got back into PC's after console gaming for so long.
So long story short few weeks back found a bargain snapped the guys hands off. It was £100.
Fx-4100 with ASUS M5A78L-M LX
Amd black edition 7950 3gig ddr5
8gig ram
Case
750W power supply ect.
Mobo is not a great piece as it's limited to 95W CPU's.
It runs pretty good, nothing amazing, but does what I want for asseto Corsa for the time being. Now the questions
Am I going to see any real benefit upgrading the FX chip? And adding more RAM?
https://linustechtips.com/topic/957653-advice/
8gig ram
Case
Most of AMD's old stuff is pretty bad so If you're happy with the performance you're getting I don't see any reason to upgrade it. The RAM, on the other hand, might benefit from being upgraded to 16 GB in general use, not so much in games.
https://linustechtips.com/topic/957653-advice/#findComment-11623367
wait till you've got enough money for at least a ryzen 1200/2200G+mobo+ram, then upgrade to that. If you really can't wait or can't save enough then even a 2nd gen i7/Xeon will run circles around any FX CPU in games.
https://linustechtips.com/topic/957653-advice/#findComment-11623411
