Ab350-Gaming 3 Bios Need help
Go to solution Solved by seon123,
Try the + key
Hello all reading this, I have built a new computer earlier this year and still need to tweak in here and there once in a while.
Long story short I use an AB350-Gaming 3 Motherboard, and want to change my RAM Voltage in the BIOS settings, but am having difficulty.
I can go into the voltage setting where it displays (auto) for 1.200V, but can't seem to change it. I have the option to enter anything from my keyboard upon clicking where it says 'auto' and then type what I wish, but it wont change.
I tried entering '1.250V' to see if that'd work but upon saving and restarting the computer nothing seems to change, and it reverts back to 'auto'. I haven't seemed to be able to find a toggle to switch it to manual or anything, is there anyone that can help? I have attached a few photos showing the Bios, the voltage options, and I wrote 'Help' to show where I can enter information but it seems to do nothing. If someone could help that'd be awesome.
Also if im doing something clearly wrong or perhaps I missed something let me know, Im not overly familiar with using my BIOS, cheers
Have you updated the bios, i had this issue before I did a bios update?
My Folding Stats - Join the fight against COVID-19 with FOLDING! - If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
  • CPU
    Ryzen 9 5950X
  • Motherboard
    Gigabyte Aorus GA-AX370-GAMING 5
  • RAM
    32GB DDR4 3200
  • GPU
    Inno3D 4070 Ti
  • Case
    Cooler Master - MasterCase H500P
  • Storage
    Western Digital Black 250GB, Seagate BarraCuda 1TB x2
  • PSU
    EVGA Supernova 1000w
  • Display(s)
    Lenovo L29w-30 29 Inch UltraWide Full HD, BenQ - XL2430(portrait), Dell P2311Hb(portrait)
  • Cooling
    MasterLiquid Lite 240
Yes it's up to date with most current BIOS F23D
odds are if you don't see an option to enable XMP on a B/H series board then you can't overclock ram from bios.
But i'm not looking to overclock I just require upping the voltage by an extra 0.05V
4 hours ago, seon123 said:
Try the + key
You my sir are a legend, so simple yet I would've never thought it, thank you so much
