The ports (usb, audio etc.) on my brothers computer are leaking power into the case making it not turn on. I don't have anything to test the electricity but with my cheek I can feel a shock like a nine volt on your tongue. Any fix for this or is he going to have to buy a new mobo?
https://linustechtips.com/topic/957002-power-leaking/
Have you tried it on different outlets?
Check the standoffs are all in properly and there's none loose or that a screws not gone between the motherboard and motherboard tray.
A faulty motherboard wouldnt cause an issue like that. it's likely something jumping the power or a grounding issue.
https://linustechtips.com/topic/957002-power-leaking/#findComment-11617227
