The CPU and motherboard come in a bundle for $369 which i think is a good deal at my local store. The case I already have here in my apartment. what do you think of this build? recommend a power supply
PCPartPicker part list: https://pcpartpicker.com/list/zs4zFt
Price breakdown by merchant: https://pcpartpicker.com/list/zs4zFt/by_merchant/
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  ($223.19 @ OutletPC)
Motherboard: ASRock - X470 Taichi ATX AM4 Motherboard  ($203.88 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($160.98 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($64.99 @ Amazon)
Video Card: MSI - GeForce GTX 1070 8GB Video Card  ($409.99 @ Amazon)
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  ($88.99 @ SuperBiiz)
Total: $1152.02
Generated by PCPartPicker 2018-08-06 14:49 EDT-0400
https://linustechtips.com/topic/956902-recommend-a-power-supply/
13 minutes ago, Daviido said:
EVGA - SuperNOVA G3 750
@LienusLateTips
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
19 minutes ago, Daviido said:
EVGA - SuperNOVA G3 750 is 80+ gold rated and will give you plenty of room for upgrades. Great build :) hope this helps
It's also really loud and has issues with its protections.
Is the 2600 available in a similar bundle? The price difference between those is usually enough to get a better cooler, which you'll want with the nice motherboard.
There are cheaper 3000MHz kits available. Get one of those. The difference between 3000 and 3200 isn't that big.
Are you sure you don't want a HDD or a larger capacity SSD?
The 1070 Ti is available for $20 more and performs quite a lot better than the 1070. Next gen Nvidia cards will also release soon-ish.
Assuming you'll overclock the 1070 Ti (or next gen equivalent), 450W is plenty. The Whisper M is a good one at a good price. Alternatively, the 550W version, if you'll get a 1080 Ti equivalent and overclock it. The Focus Plus Gold 550W is a bit cheaper than the Whisper M 550W, if you want to save a little.
I bought a Hard drive already  its a seagate barucuda and its already here in my apartment.
You do not think the stock cooler will work?
