Hi, I have a intel G4560 (Bad decision) and I have looked at a i5 8400 for an upgrade but I have been wondering if I should get a graphics card first (I don’t have one right now using integrated graphics) - looking at a gtx 1050. I was wondering what should I get first??
I do a YouTube channel and light video editing, sometimes use Blender for light animations, Fortnite, Roblox (cringe), looking into more games if my gaming wasn’t slow, small projects. - that’s the sort of stuff I would use. Any suggestions on what to get first.
Thank you everyone,
(I not sure I posted to the right sub forum.
Nic
https://linustechtips.com/topic/956656-advice-for-an-upgrade/
2 hours ago, teddy9264 said:
Thanks
1060 will max out what the CPU can do in Gaming.
How much memory & what speed to you have? That'll make upgrade paths a little easier to work out. (Likely a new motherboard + i5-8400 would work; or a R5 1600/2600.)
https://linustechtips.com/topic/956656-advice-for-an-upgrade/#findComment-11636489
